Mark Alington Posted June 4, 2020 Report Share Posted June 4, 2020 I want to record a chase of a number of units. Then independantly I want to control the colour of all these units, possibly from a variety of plabacks. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 4, 2020 Report Share Posted June 4, 2020 Hi Mark, To do this, you can program your chase which will control just the intensity of the fixtures, and you can then program playbacks that just control colour. The simplest way to do this, is firstly push up the intensities of all your fixtures to full, and then record this to a playback fader. Then push this playback fader up, so the fixtures come on in their default colour (white). Then select the fixtures and choose the colour you wish to store, and then press and hold RECORD. From the Record Options window that opens, ensure SmartTag is disabled, indicated with a blue stripe. If it is enabled (red stripe) the console will include intensity with your colour. You just want colour to be stored, not intensity, that way intensity can be controlled by the chase playback separately. Then tap the flashing playback button you wish to store your colour to. Then repeat this process for all of your colours. You won't need to press and hold RECORD each time, as once SmartTag is disabled in the Record Options it will stay disabled until you enable it again. If you cannot see a SmartTag button in the Record Options window, see below... http://support.zero88.com/1014189311 Then double tap CLEAR, and program your intensity chase, ensuring not to include any colour information. Once you have done this, you should find you can raise your chase playback, and introduce colours over the top using your colour playbacks. You will probably find you want to enable fader controls colour on the colour playbacks. To do this, press and hold SETUP and tap your colour playback's button, and then choose Colour under fader controls, so that it has a red stripe. Fore more information, see below... http://support.zero88.com/1011405471 To turn SmartTag back on for future programming, press and hold RECORD, tap SmartTag so it has a red stripe, and then tap RECORD to save and close the window. Hope this helps, if you have any questions let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 4, 2020 Report Share Posted June 4, 2020 (I have updated the topic title just to make it a little more specific) Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
kgallen Posted June 4, 2020 Report Share Posted June 4, 2020 Edward - you should start a "How To" list on the KB of "how to do kool things" and add this to it. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 4, 2020 Report Share Posted June 4, 2020 7 minutes ago, kgallen said: Edward - you should start a "How To" list on the KB of "how to do kool things" and add this to it. Done: http://support.zero88.com/1963020271 Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
kgallen Posted June 4, 2020 Report Share Posted June 4, 2020 10 minutes ago, Edward- Z88 said: Done: http://support.zero88.com/1963020271 🤣 ... duly hidden away under Legacy Consoles -> Orb XF! 😂 Thanks! Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 4, 2020 Report Share Posted June 4, 2020 12 minutes ago, kgallen said: 🤣 ... duly hidden away under Legacy Consoles -> Orb XF! 😂 Thanks! Yes - what would be best is to just remove the legacy products for now. Will do that shortly. Just to give you a heads up, we will soon be bringing our manuals online. As this is done, information on the knowledge base will also be transferred and included in the relevant parts of the manual. The knowledge base will then be surplus to requirements. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 4, 2020 Report Share Posted June 4, 2020 2 hours ago, kgallen said: 🤣 ... duly hidden away under Legacy Consoles -> Orb XF! 😂 Thanks! Updated Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Mark Alington Posted June 5, 2020 Author Report Share Posted June 5, 2020 Thanks Edward. I've got all this working. I spent a lot of the time untagling my channels from the playbacks on the different pages! I'll post another query elsewhere unless I can find it already answered. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 5, 2020 Report Share Posted June 5, 2020 16 minutes ago, Mark Alington said: Thanks Edward. I've got all this working. I spent a lot of the time untagling my channels from the playbacks on the different pages! I'll post another query elsewhere unless I can find it already answered. Great glad you’ve got that working. Sure - any other questions let us know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
