Simonkbike Posted May 20, 2020 Report Posted May 20, 2020 Hi, I've watched some of the training videos you're streaming and, although naturally based on the FLX board, they will be useful to us Solution users too. Most of the time it's fairly to translate to Solution but there must be some command or syntax that's less obvious or impossible. It would be helpful to have a translation grid of which FLX commands work on Solution desk ( & maybe other models) and which don't, and how to convert instructions from FLX to Solution. Cheers Simon Quote
Edward Z88 Posted May 20, 2020 Report Posted May 20, 2020 Hi Simon, Thanks for your comments. Hope you've been enjoying the streams. Yes - the streams will definitely be of use to Solution users too. 1 hour ago, Simonkbike said: It would be helpful to have a translation grid of which FLX commands work on Solution desk ( & maybe other models) and which don't, and how to convert instructions from FLX to Solution. We currently don't have this, but this is something we could look to create. In terms of general features, we have the comparison sheet below... https://zero88.com/control#compare Hope this helps, if you have any questions let us know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
