Grand Master allows desk output while at zero when desk first swtched on
With Grand Master operation enabled, latching operation, and the desk is turned on, the channel faders will output levels from the desk, even though the Grand Master is at zero and the Go button LED is off. Once the Grand Master is raised above zero, the Go button LED flashes slowly and once the Master Fader reaches the level of the channel faders it takes over control. Is this a bug ?
When you switch the console on, the Grand Master defaults at full.
Otherwise, if a fader on page 2 for example was a grand master, after booting the console there would be no light output until you found the correct fader, and pushed it up.
Hope this helps,
