stowedout Posted March 23, 2020 Report Posted March 23, 2020 Hi Zero88 team, Hope you are all staying safe in these difficult times. Can you confirm how playbacks are numbered for midi purposes (for info my FLX set to midi channel 1). My understanding is that there are 128 notes in each midi channel, therefore If playback 1 is midi note 1. Does playback 129 get pushed up to Channel 2 midi note 1? Chris Quote
Edward Z88 Posted March 23, 2020 Report Posted March 23, 2020 Hi Chris, 6 minutes ago, stowedout said: Hope you are all staying safe in these difficult times. Yes thank you - hope you are too. 6 minutes ago, stowedout said: Can you confirm how playbacks are numbered for midi purposes ZerOS can only be set to receive a single MIDI Notes channel number. There are 16 channels in total (0-15). 128 playbacks can therefore be triggered from a single MIDI Notes channel (MIDI Note Pitch 0-127). A fade time can be applied using the velocity. For more information see below... http://support.zero88.com/990063141 Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
stowedout Posted March 23, 2020 Author Report Posted March 23, 2020 Thanks Edward, So is that the first 128 playbacks only with no way of pushing the start point up the playback list. Chris Quote
Edward Z88 Posted March 23, 2020 Report Posted March 23, 2020 Hi Chris, That is correct, MIDI Notes will trigger playbacks 1-128, with no way of applying an offset. Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
stowedout Posted March 23, 2020 Author Report Posted March 23, 2020 Cheers good to know. I was trying to run page 5 upwards via midi. Explains why I was hitting a brick wall. Re-jig required Chris Quote
Edward Z88 Posted March 23, 2020 Report Posted March 23, 2020 Hi Chris, 1 hour ago, stowedout said: Cheers good to know. No problem. Any questions let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
