AdamSk Posted March 16, 2020 Report Share Posted March 16, 2020 With RigSync on, is it possible to manually change fixture modes/personalities from the desk, and similarly, can the DMX address be set for each fixture manually (from the desk), rather than having the desk assign them? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted March 16, 2020 Report Share Posted March 16, 2020 Hi Adam, Yes that is correct. If you have RDM enabled fixtures connected to FLX S, it should be able to detect them, and patch them for you. If you then change the fixture's mode, or change its address from the console, the settings will also change on the fixture. For more information, see the video below... Hope this helps, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
AdamSk Posted March 17, 2020 Author Report Share Posted March 17, 2020 Thanks for the info, works great! Quote Link to comment Share on other sites More sharing options...
