AdamSk Posted March 16, 2020 Report Posted March 16, 2020 With RigSync on, is it possible to manually change fixture modes/personalities from the desk, and similarly, can the DMX address be set for each fixture manually (from the desk), rather than having the desk assign them? Quote
Edward Z88 Posted March 16, 2020 Report Posted March 16, 2020 Hi Adam, Yes that is correct. If you have RDM enabled fixtures connected to FLX S, it should be able to detect them, and patch them for you. If you then change the fixture's mode, or change its address from the console, the settings will also change on the fixture. For more information, see the video below... Hope this helps, Edward Quote Edward Smith Product Specialist Email Support
AdamSk Posted March 17, 2020 Author Report Posted March 17, 2020 Thanks for the info, works great! Quote
