With RigSync on, is it possible to manually change fixture modes/personalities from the desk, and similarly, can the DMX address be set for each fixture manually (from the desk), rather than having the desk assign them?
Hi Adam,
Yes that is correct. If you have RDM enabled fixtures connected to FLX S, it should be able to detect them, and patch them for you. If you then change the fixture's mode, or change its address from the console, the settings will also change on the fixture.
For more information, see the video below...
Hope this helps,
