Shadowwalker0408 Posted March 13, 2020 Report Share Posted March 13, 2020 On the FLX Zero 88 there is a 1/4 inch sound input, apprantly you can take an output from a sound desk and the lights will match either the bass, middle or high of the sound and sync with the beats. I have looked for ages and can't find out how to do this. Can anyone help? Quote Link to comment Share on other sites More sharing options...
Davidmk Posted March 13, 2020 Report Share Posted March 13, 2020 Not used it myself but sound to light is mentioned on pages 43 and 81 of the manual. If you are not a sound engineer then talk to one, you may need something between the two desks (sound desks tend to use a balanced connection on XLR while this input looks to be an unbalanced stereo one and a conversion may be needed). Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted March 13, 2020 Report Share Posted March 13, 2020 Hi both, The audio input can trigger chases to run. When you’ve programmed a chase, you can go into its settings, and enable sound to light. The audio jack input can be a balanced or unbalanced signal. Many sound consoles have jack outputs for monitors, which you can take a feed from and plug into the console. For best results, feed a bass filtered signal, so the console knows what to step the chase’s cues to. It’s always good to also have the ability to adjust the volume level entering the console. Hope this helps, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
Tony B Posted October 4, 2021 Report Share Posted October 4, 2021 On 3/13/2020 at 6:47 PM, Edward Z88 said: Hi both, The audio input can trigger chases to run. When you’ve programmed a chase, you can go into its settings, and enable sound to light. The audio jack input can be a balanced or unbalanced signal. Many sound consoles have jack outputs for monitors, which you can take a feed from and plug into the console. For best results, feed a bass filtered signal, so the console knows what to step the chase’s cues to. It’s always good to also have the ability to adjust the volume level entering the console. Hope this helps, Edward Hi, Is there anythimg else needed to do? I have done all the above but nothing is happening, I have a recorded chase and sound out from my mixer via aux monitor... Thanks Tony Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 4, 2021 Report Share Posted October 4, 2021 Hi Tony, 2 hours ago, Tony B said: Is there anythimg else needed to do? I have done all the above but nothing is happening, I have a recorded chase and sound out from my mixer via aux monitor... You shouldn't need to do anything else - connect your audio feed, enable Sound to Light on a chase, and then run the chase... https://zero88.com/manuals/zeros/cues-playbacks/chases/chase-settings You may find it easiest to set the Chase's speed to 1 BPM - that way you can see the Sound To Light triggers more easily. If there doesn't seem to be any audio reaching the console, you can boot the console into Test Mode. For information on accessing Test Mode, please see the link below... https://zero88.com/manuals/zeros/trouble-shooting/test-mode If you choose the "Other Test" tab at the top, this will then show you the audio levels being received. If you have any questions let me know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
