nbaldwin Posted March 12, 2020 Report Posted March 12, 2020 As per the title, anyone recommend a reasonably priced touch-screen monitor for a Leapfrog 96? Thanks, Neil Quote
Edward Z88 Posted March 12, 2020 Report Posted March 12, 2020 Hi Neil, For a list of known compatible touchscreens, see below... http://support.zero88.com/975056031 Our new touchscreens we use for demos can be found below... https://iiyama.com/gl_en/products/prolite-t2236msc-b2/ Hope this helps, Edward Quote Edward Smith Product Specialist Email Support
van den abbeele Eric Posted April 7, 2020 Report Posted April 7, 2020 Hello Edward, Do you see differents between your previous Touchscreens display (Prolite T1731SR) and your new Prolite t2236msc-b2 ? thank for your help, eric Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
Edward Z88 Posted April 7, 2020 Report Posted April 7, 2020 Hi Eric, On 4/7/2020 at 10:10 AM, van den abbeele Eric said: Do you see differents between your previous Touchscreens display The big difference is that the Prolite T2236MSC-B2 are wide screen, and support capacitive touch. Capacitive touch screen technology allows for multitouch, like on the FLX internal touchscreen, or on an iPad for example. The older Prolite T1731SR touchscreens used resistive technology, only allowing for single touch. Edward Quote Edward Smith Product Specialist Email Support
van den abbeele Eric Posted April 15, 2020 Report Posted April 15, 2020 Hi Edward, OK thank for you answers. So do you see many advantage since you have this new Prolite with capactive technology ? Or not so much ? Thank for your help Take care ! Eric Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
Edward Z88 Posted April 15, 2020 Report Posted April 15, 2020 Hi Eric, 5 hours ago, van den abbeele Eric said: So do you see many advantage since you have this new Prolite with capactive technology ? Or not so much ? They're much nicer to use as you don't have to press as hard, plus as I mentioned also allow for multitouch so you can fan using the colour picker externally. Edward Quote Edward Smith Product Specialist Email Support
van den abbeele Eric Posted April 15, 2020 Report Posted April 15, 2020 thank for your answers. Take care of yourself Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
van den abbeele Eric Posted June 10, 2020 Report Posted June 10, 2020 So I've buy this new monitor and It s better to use. More réactif between FLX and Touching. Thank Eric Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
kgallen Posted June 10, 2020 Report Posted June 10, 2020 Is there a smaller version of this new capacitive touch screen more like the size of the resistive one? I don’t have desk space for a 22”. Kevin Quote
Edward Z88 Posted June 11, 2020 Report Posted June 11, 2020 Hi Kevin, Just had a quick look... https://iiyama.com/gl_en/products/touchscreens/all/all/#/filter/category:4 (After getting side tracked by the 86" 4K touchscreen!!) Looks like if you want wide screen they do some 15.6" capacitive touchscreens if you want something a little smaller. Edward Quote Edward Smith Product Specialist Email Support
kgallen Posted June 11, 2020 Report Posted June 11, 2020 Oooo, thanks Edward! However you might need to help me narrow it down a bit! They have a huge range of monitors don't they! Re 15.6", is it only the two 15.6" ones or would I just be looking for one with "P-Cap" or "Projective Capacitive" since there are quite a few 15" described like that. What about aspect ratio? Anyone want a lightly used Iiyama resistive touchscreen?! Thanks, Kevin Quote
Edward Z88 Posted June 11, 2020 Report Posted June 11, 2020 Hi Kevin, 32 minutes ago, kgallen said: "P-Cap" or "Projective Capacitive" P-Cap and Projective Capacitive are the same thing - basically means it will feel more like a smart phone touchscreen, allowing for multi-touch, rather than the feel of your resistive touchscreen. Regarding aspect ratio, FLX doesn't mind 4:3 or 16:9, so it is up to you which you'd prefer. Regarding resolution, FLX can support 1920 x 1080, but will auto adjust and accept the standard resolutions. Looks like the max resolution of iiyama's 15.6" is 1366 x 720, which is fair enough. Most of these integrate a USB hub, which is always nice too. Edward Quote Edward Smith Product Specialist Email Support
van den abbeele Eric Posted June 11, 2020 Report Posted June 11, 2020 Hello, It s good to know that ! thank eric Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
kgallen Posted June 12, 2020 Report Posted June 12, 2020 We have to be careful with that Iiyama page because not all of those monitors support DVI-D required by FLX. The following URL includes the filter for DVI, although it's still not clear to me if this implies DVI-D is supported, since FLX does not output DVI-A. Anyway, this gets us closer to picking a compatible touch screen: Iiyama Capacitive Touchscreens with DVI in Black BUT even with the DVI filter applied above, the page is listing monitors without DVI inputs. I just clicked on the T1732MSC-B5X for instance, returned by this search, and DVI is not listed as an input interface. BEWARE! Alas, when you find one with DVI, it seems the 15", 17" and 19" are the same price, if not more than the 22" Edward quotes above (in the UK at least). Quote
Edward Z88 Posted June 12, 2020 Report Posted June 12, 2020 Hi Kevin, Thanks for looking into this. Worth mentioning FLX would be compatible with monitors with an HDMI input, however a DVI to HDMI cable would be required, rather than DVI to DVI. Cheers, Edward Quote Edward Smith Product Specialist Email Support
van den abbeele Eric Posted June 17, 2020 Report Posted June 17, 2020 Hello of all Users for helping new users. I did a research about FLX Monitor. and on this list and all the red monitor looks to be stop Perhaps it ll be good to have a Update about the list. Important things are : - DVI- D - USB connection - Better with Captatif technology. - others things ? Thank Eric Result after research : Iiyama Prolite T1731SR-B1 – Résistif Iiyama Prolite T1531SR - Résistif Iiyama Prolite T2252MTS-B3 - Iiyama Prolite T1932MSC-W2AG - Captatif - Multi Iiyama Prolite T2236MSC-B1 – Iiyama Prolite T1931SR-B1A -Resistif Iiyama Prolite TF2234MC – Captatif - Multi Iiyama Prolite T2236MSC-B2 – Captatif - Multi Viewsonic TD2220-2 – Multi Dell ST2220T - Multi Dell P2418HT - Hanns-G HT231 - Planar PT1985P - HP E230t – Captatif - Multi Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
Edward Z88 Posted June 17, 2020 Report Posted June 17, 2020 Hi Eric, Thanks for looking into this. We will leave the touchscreens that have been discontinued on the list, just so that if people have one lying around or buy second hand they are still known to work. Cheers, Edward Quote Edward Smith Product Specialist Email Support
Edward Z88 Posted June 17, 2020 Report Posted June 17, 2020 (I have deleted your duplicate post just to keep this information all in one thread and topic) Quote Edward Smith Product Specialist Email Support
van den abbeele Eric Posted June 17, 2020 Report Posted June 17, 2020 OK Edward, thank Eric Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
van den abbeele Eric Posted July 16, 2020 Report Posted July 16, 2020 Hello for all, have you experienced other external monitor ? Having good experience with other brand and models ? Thank a lot Eric Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
Ed75 Posted January 17, 2023 Report Posted January 17, 2023 I tried to post this earlier , but due to the recent forumproblems I'll do it now: Used and tested by me are a 22" Iiyama, a 13" Beetronics, (or a cheaper chinese version of them) and recently a Waveshare 15,6" portable multi touch screen. I found the 22" a bit large in theatrevenues where the tech seats are in the audience, specially combined with my Solution, which itself is quite high staying in its flightcase. After purchasing a FLX I needed a third screen and started looking for something not too small, but modest, and found this 15'6" Waveshare screen. Works very smooth, well-defined touch. And for a portable nice: it has the standard 100x100 Vesa-mount holes. So easy to put on a higher stand. So two more brands you could probably add to the list: Beetronics and Waveshare. Both brands require no drivers and work with Zeros. 1 Quote Freelance Theatre Lighting designer/operator/allround technician/tech production/rental . Netherlands. FLX, FLX S48 2U, Solution, 13" multitouch monitor, 15" portable multitouch monitor, 11.4" lenovo thinkpad touch, network hub with wifi, powered usb hub, keyboard, trackball. 2x Elgato Streamdeck, nodes: showtec 2-3 and Lightshark node-4 2x 19" networkswitch, IOS zeros remote. 22" Iiyama.
