Touch Screen Monitor Recommendation
nbaldwin
  • 4 weeks later...
Hello Edward,
Do you see  differents between your previous Touchscreens display (Prolite T1731SR) and your new Prolite t2236msc-b2 ?
thank for your help,
eric
Hi Eric,
The big difference is that the Prolite T2236MSC-B2 are wide screen, and support capacitive touch. Capacitive touch screen technology allows for multitouch, like on the FLX internal touchscreen, or on an iPad for example. The older Prolite T1731SR touchscreens used resistive technology, only allowing for single touch.
Product Specialist
Email Support
  • 2 weeks later...
Hi Edward,
OK thank for you answers.
So do you see many advantage since you have this new Prolite with capactive technology ? Or not so much ?
Thank for your help
Take care !
Eric
Hi Eric,
They're much nicer to use as you don't have to press as hard, plus as I mentioned also allow for multitouch so you can fan using the colour picker externally.
Product Specialist
Email Support
thank for your answers.
Take care of yourself
  • 1 month later...
So I've buy this new monitor and It s better to use.
More réactif between FLX and Touching.
Thank
Eric
Hi Kevin,
Just had a quick look...
https://iiyama.com/gl_en/products/touchscreens/all/all/#/filter/category:4
(After getting side tracked by the 86" 4K touchscreen!!) Looks like if you want wide screen they do some 15.6" capacitive touchscreens if you want something a little smaller.
Product Specialist
Email Support
Oooo, thanks Edward!
However you might need to help me narrow it down a bit! They have a huge range of monitors don't they!
Re 15.6", is it only the two 15.6" ones or would I just be looking for one with "P-Cap" or "Projective Capacitive" since there are quite a few 15" described like that.
What about aspect ratio?
Anyone want a lightly used Iiyama resistive touchscreen?!
Thanks,
Kevin
Hi Kevin,
P-Cap and Projective Capacitive are the same thing - basically means it will feel more like a smart phone touchscreen, allowing for multi-touch, rather than the feel of your resistive touchscreen.
Regarding aspect ratio, FLX doesn't mind 4:3 or 16:9, so it is up to you which you'd prefer.
Regarding resolution, FLX can support 1920 x 1080, but will auto adjust and accept the standard resolutions. Looks like the max resolution of iiyama's 15.6" is 1366 x 720, which is fair enough.
Most of these integrate a USB hub, which is always nice too.
Product Specialist
Email Support
It s good to know that !
thank
eric
We have to be careful with that Iiyama page because not all of those monitors support DVI-D required by FLX. The following URL includes the filter for DVI, although it's still not clear to me if this implies DVI-D is supported, since FLX does not output DVI-A. Anyway, this gets us closer to picking a compatible touch screen:
Iiyama Capacitive Touchscreens with DVI in Black
BUT even with the DVI filter applied above, the page is listing monitors without DVI inputs. I just clicked on the T1732MSC-B5X for instance, returned by this search, and DVI is not listed as an input interface. BEWARE!
Alas, when you find one with DVI, it seems the 15", 17" and 19" are the same price, if not more than the 22" Edward quotes above (in the UK at least).
Hello of all Users for helping new users.
I did a research about FLX Monitor.
and on this list and all the red monitor looks to be stop
Perhaps it ll be good to have a Update about the list.
Important things are :
- DVI- D
- USB connection
- Better with Captatif technology.
- others things ?
Thank Eric
Result after research :
Iiyama
Prolite T1731SR-B1 – Résistif
Iiyama
Prolite T1531SR - Résistif
Iiyama
Prolite T2252MTS-B3 -
Iiyama
Prolite T1932MSC-W2AG - Captatif - Multi
Iiyama
Prolite T2236MSC-B1 –
Iiyama
Prolite T1931SR-B1A -Resistif
Iiyama
Prolite TF2234MC – Captatif - Multi
Iiyama
Prolite T2236MSC-B2 – Captatif - Multi
Viewsonic
TD2220-2 – Multi
Dell
ST2220T - Multi
Dell
P2418HT -
Hanns-G
HT231 -
Planar
PT1985P -
HP
E230t – Captatif - Multi
OK Edward,
thank
Eric
  • 4 weeks later...
Hello for all,
have you experienced other external monitor ? Having good experience with other brand and models ?
Thank a lot
Eric
  • 2 years later...
I tried to post this earlier , but due to the recent forumproblems I'll do it now:
Used and tested by me are a 22" Iiyama, a 13" Beetronics, (or a cheaper chinese version of them) and recently a Waveshare 15,6" portable multi touch screen.
I found the 22" a bit large in theatrevenues where the tech seats are in the audience,  specially combined with my Solution, which itself is quite high staying in its flightcase.
After purchasing a FLX I needed a third screen and  started looking for something not too small, but modest, and found this 15'6" Waveshare screen. Works very smooth, well-defined touch. And for a portable nice: it has the standard 100x100 Vesa-mount holes. So easy to put on a higher stand.
So two more brands you could probably add to the list: Beetronics and Waveshare. Both brands require no drivers and work with Zeros.
  • Like 1
