Neill45 Posted March 11, 2020 Report Posted March 11, 2020 Hi I,m trying control a few Robe 160xt heads using my new FLX S 48 and was wondering if the lamp fader can be altered to control the shutter. Otherwise the the lamps are automatically on when I power up. thanks for any help
Edward Z88 Posted March 11, 2020 Report Posted March 11, 2020 Hi Neil, Im guessing these fixtures just have a shutter, and no intensity parameter. If so it should default to the shutter being closed. If it isn’t, there may be an error with the fixture file. To edit the fixture’s defaults on the console, select the fixture, close the shutter, tap RECORD, and then tap the Home icon, and store as defaults. Make sure you have SmartTag disabled when doing this. For more information, see below... http://support.zero88.com/1011707631 Hope this helps, Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
