O Thompson Posted March 9, 2020 Report Share Posted March 9, 2020 Hi Folks, can anyone assist with ZerOS and Capture? I have the capture demo running on my PC and Phantom ZerOS also running on my PC, but i cant seem to get capture to see or respond to ZerOS. Quote Link to comment Share on other sites More sharing options...
kgallen Posted March 9, 2020 Report Share Posted March 9, 2020 Hi Ollie, Does anything in this recent thread help? Kevin Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted March 9, 2020 Report Share Posted March 9, 2020 Hi Olly, For information on how to connect Capture and Phantom on the same PC, see below... http://support.zero88.com/988883201 If you have any questions let me know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
kgallen Posted March 9, 2020 Report Share Posted March 9, 2020 I was first for a change! 🤩😝 (no accounting for quality of course!!!) Quote Link to comment Share on other sites More sharing options...
O Thompson Posted March 9, 2020 Author Report Share Posted March 9, 2020 Thanks for the swift replies... Edward, the link you provided doesn't seem to help... Shift +F10 has no response when using phantom ZerOS with the FLX sim? Quote Link to comment Share on other sites More sharing options...
kgallen Posted March 9, 2020 Report Share Posted March 9, 2020 Ollie - interested how you get on. I bought Capture (at great expense) a fair few months back, but to date haven't had the guts to try and connect it to FLX... (desk or Phantom). Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted March 9, 2020 Report Share Posted March 9, 2020 Hi Olly, SHIFT + F10 is the keyboard shortcut for the SETUP key. This will work if your active window is the LCD or External Monitor windows. To make them active click in the Windows, or close and reopen the window from the Phantom launcher. Hope this helps, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
O Thompson Posted March 9, 2020 Author Report Share Posted March 9, 2020 It may be worth noting that i am using a works PC and i am unable to re allocate the machines IP Quote Link to comment Share on other sites More sharing options...
O Thompson Posted March 9, 2020 Author Report Share Posted March 9, 2020 1 minute ago, Edward- Z88 said: Hi Olly, SHIFT + F10 is the keyboard shortcut for the SETUP key. This will work if your active window is the LCD or External Monitor windows. To make them active click in the Windows, or close and reopen the window from the Phantom launcher. Hope this helps, Edward ah ok. In that case, on the FLX sim there is no "visualiser" option. I have already enabled remote apps in devices (is this required) and selected the 127.0.0.1 IP option. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted March 9, 2020 Report Share Posted March 9, 2020 2 minutes ago, O Thompson said: It may be worth noting that i am using a works PC and i am unable to re allocate the machines IP You won't need to change any IPs if you are controlling Capture from Phantom on the same PC, as you will; simply need the PCs loopback IP of 127.0.0.1. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
O Thompson Posted March 9, 2020 Author Report Share Posted March 9, 2020 2 minutes ago, Edward- Z88 said: Hi Olly, SHIFT + F10 is the keyboard shortcut for the SETUP key. This will work if your active window is the LCD or External Monitor windows. To make them active click in the Windows, or close and reopen the window from the Phantom launcher. Hope this helps, Edward I actually had it working quite successfully with the physical console. However in that case it was on an isolated network. We have a separate network setup in the venue for remote control of the FLX and X32 consoles, which allows me more control over the IP allocations. Quote Link to comment Share on other sites More sharing options...
O Thompson Posted March 9, 2020 Author Report Share Posted March 9, 2020 Right... found a setting under the "universes" tab of setup that allows me to alter the IP for CITP. this works with the Dockhouse demo, but not when im creating a new project... is there a specific setting in capture that i might be missing? Quote Link to comment Share on other sites More sharing options...
O Thompson Posted March 9, 2020 Author Report Share Posted March 9, 2020 ok, so by loading capture before zeros, and then toggling between the PC ip and the 127.0.0.1 ip on the universes section of the FLX phantoOS, i get control... not sure why the toggle between ip's is needed. but in this case it works. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted March 9, 2020 Report Share Posted March 9, 2020 Hi Olly, I have updated the guide as per Phantom ZerOS 7.9.7, as the CITP option is now under Universes rather than Visualisation. You should find if you start Capture with Phantom's CITP IP of 127.0.0.1 chosen, Capture detects the CITP protocol. Toggling from and then back to the 127.0.0.1 will prompt Capture to detect this IP. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
O Thompson Posted March 9, 2020 Author Report Share Posted March 9, 2020 Thanks Edward, Much appreciated as always. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted March 9, 2020 Report Share Posted March 9, 2020 Just now, O Thompson said: Thanks Edward, Much appreciated as always. No problem, any questions let me know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
kgallen Posted March 9, 2020 Report Share Posted March 9, 2020 Apparently this topic is now HOT! Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted March 9, 2020 Report Share Posted March 9, 2020 5 minutes ago, kgallen said: Apparently this topic is now HOT! Smokin' Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
kgallen Posted March 9, 2020 Report Share Posted March 9, 2020 8 minutes ago, Edward- Z88 said: Smokin' No, tha's Ollie's FLX 🤣 Quote Link to comment Share on other sites More sharing options...
O Thompson Posted March 10, 2020 Author Report Share Posted March 10, 2020 Ha! just got it back from repair so i hope not... Quote Link to comment Share on other sites More sharing options...
