Nick Kodizas Posted February 27, 2020 Report Share Posted February 27, 2020 Hello, I am setting up an old workhorse (Leap Frog 48). The only problem I have is that I am missing the main screen (The screen between the setup and record buttons). I've tried to contact my local authorized resellers for spare parts and I can't get a hold of them. It has been 6 months and I haven't heard anything from them. Can I purchase the screen from you? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted February 27, 2020 Report Share Posted February 27, 2020 Hi Nick, To find your nearest Zero 88 distributor, please see below... https://zero88.com/distributors/map Once you have found a distributor, please contact them for a quote. The part number for the Main LCD PCB is 1214799. If you have any questions let us know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
kgallen Posted February 27, 2020 Report Share Posted February 27, 2020 If you're suitably competent, maybe worth opening the desk up an checking for loose ribbon cables. Maybe Edward can consult the mechanical drawings and advise if this screen is directly soldered or if there is a candidate cable of some sort. Also the minimal set of screws to remove to gain access. On Fat Frog for instance (similar case design) it is just one per side, the lower one to the rear of the side panels. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted February 27, 2020 Report Share Posted February 27, 2020 Hi Kevin, 31 minutes ago, kgallen said: Maybe Edward can consult the mechanical drawings and advise if this screen is directly soldered or if there is a candidate cable of some sort. From memory the LCD is directly on the PCB so no usual suspects of ribbon cables. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
iank99 Posted March 2, 2020 Report Share Posted March 2, 2020 On 2/27/2020 at 12:24 PM, Edward- Z88 said: Hi Kevin, From memory the LCD is directly on the PCB so no usual suspects of ribbon cables. Edward I think Edward is correct - been a while since I had to swap out this particular PCB - might be worth checking the pins for the LCD for dry joints, they can happen and cause weirdness. If that's no good then it will have to be a new PCB - I can supply the PCB (though not from stock sadly) if that helps you? My Profile has my website address - I would expect the PCB's to be 7-10 working days to stock but I can check this if you want to order from me. Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk Link to comment Share on other sites More sharing options...
