Uriahdemon Posted February 26, 2020 Report Share Posted February 26, 2020 Hi, on reading the manual it states 'each of the outputs can be mapped to any of the DMX universes'. Has anyone done this and how did you do it. Also am I correct to assume you need to get the Universe Upgrade applied before being able to do so. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
kgallen Posted February 26, 2020 Report Share Posted February 26, 2020 You don't need to pay any more money. The desks are limited by channel count (2048 on unexpanded FLX) not by Universe. When you patch a fixture you can assign the DMX address to any universe 1-64. Under Setup you might need to check that the universe is enabled and which physical output (XLR) it's assigned to. But no, I've not currently ever done this myself! 🤣 Kevin Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted February 26, 2020 Report Share Posted February 26, 2020 Hi Mac, 1 hour ago, Uriahdemon said: it states 'each of the outputs can be mapped to any of the DMX universes'. Correct, as Kevin says, you can patch your fixtures across 64 universes. Then under Universes in Setup, you can choose how these universes are routed from the console, whether they be over Ethernet or DMX outputs. If you have a 4 universe FLX, you therefore have 4 universes of channels (2048) to patch across 64 universes. An example of where you might do this is if you need 10 lines of DMX, where each line has fixtures starting at DMX address 1. You therefore patch these fixtures across 10 universes, and you can output a pair of universes out the back of the console, and then 8 to an Ethernet to DMX Gateway. As long as the total amount of channels consumed doesn't exceed 2048 channels, you can do this on a 4 universe FLX. Our new 8 port Ethernet to DMX gateway "Gateway 8", is being released later this year... https://zero88.com/data/gateway8 Hope this helps, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
kgallen Posted February 26, 2020 Report Share Posted February 26, 2020 22 minutes ago, Edward- Z88 said: Our new 8 port Ethernet to DMX gateway "Gateway 8", is being released later this year... https://zero88.com/data/gateway8 ...and that, you will have to pay (quite a lot) for! 😈 Quote Link to comment Share on other sites More sharing options...
Uriahdemon Posted February 26, 2020 Author Report Share Posted February 26, 2020 Thanks both, much appreciated. So as I read it the desk I have is capable of outputting 4 universes to physical output 1 or 2. The thing is how do I actually do that. I went into setup>universes and tried what I thought was a logical change but it stayed as was.....?? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted February 26, 2020 Report Share Posted February 26, 2020 Hi Mac, 11 minutes ago, Uriahdemon said: the desk I have is capable of outputting 4 universes to physical output 1 or 2. You can route any desk universe (any universe between universe 1-64) to either of the DMX outputs. To do this, tap SETUP -> Universes -> scroll down to the desk universe you wish to route from the console. Then open the panel for that universe, and you can then route the universe over Ethernet, or from either/both of the DMX outputs. To do this click Add under DMX, type the port number (either 1 or 2), and click OK. If that output is currently transmitting a different desk universe, you will get a popup to warn you of this, which you can then click OK. You will then have a RigSync option appear for that output. Hope this helps, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Uriahdemon Posted February 26, 2020 Author Report Share Posted February 26, 2020 Thanks Ed I will give it a go tomorrow. Quote Link to comment Share on other sites More sharing options...
Roamin Posted September 14, 2020 Report Share Posted September 14, 2020 Bonjour, Si on a pas assé avec les 2048 canaux, on peut acheter des canaux ou univers supplémentaire? on peut monter a 32 768 canaux ( soit 64 univers)? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 14, 2020 Report Share Posted September 14, 2020 Bonjour, Si vous disposez d'un FLX à 4 univers (2048 canaux), vous pouvez ajouter des univers DMX supplémentaires, jusqu'à un maximum de 16 univers (8192 canaux). Ces univers peuvent être patchés sur 64 univers. https://zero88.com/upgrade/ J'espère que cela t'aides, Hello, If you have a 4 universe (2048 channels) FLX, you can add additional DMX universes, up to a maximum of 16 universes (8192 channels). These universes can be patched across 64 universes. https://zero88.com/upgrade/ Hope this helps, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Roamin Posted September 17, 2020 Report Share Posted September 17, 2020 super merci Quote Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted September 20, 2020 Report Share Posted September 20, 2020 Bonjour, oui ensuite il est possible de faire cumuler plusieurs console ensemble. FLX 1 Univers 1 à 16 FLX 2 Univers 17 à 32 FLX 3 Univers 33 à 48 FLX Univers 49 à 64. Cela fait deja pas mal de choses possibles... Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 3 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 5 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w Link to comment Share on other sites More sharing options...
