Use of additional Universes on FLX
Uriahdemon
You don't need to pay any more money. The desks are limited by channel count (2048 on unexpanded FLX) not by Universe.
When you patch a fixture you can assign the DMX address to any universe 1-64. Under Setup you might need to check that the universe is enabled and which physical output (XLR) it's assigned to.
But no, I've not currently ever done this myself! 🤣
Kevin
Hi Mac,
1 hour ago, Uriahdemon said:
it states 'each of the outputs can be mapped to any of the DMX universes'.
Correct, as Kevin says, you can patch your fixtures across 64 universes. Then under Universes in Setup, you can choose how these universes are routed from the console, whether they be over Ethernet or DMX outputs.
If you have a 4 universe FLX, you therefore have 4 universes of channels (2048) to patch across 64 universes.
An example of where you might do this is if you need 10 lines of DMX, where each line has fixtures starting at DMX address 1. You therefore patch these fixtures across 10 universes, and you can output a pair of universes out the back of the console, and then 8 to an Ethernet to DMX Gateway. As long as the total amount of channels consumed doesn't exceed 2048 channels, you can do this on a 4 universe FLX.
Our new 8 port Ethernet to DMX gateway "Gateway 8", is being released later this year...
https://zero88.com/data/gateway8
Hope this helps,
Hi Mac,
11 minutes ago, Uriahdemon said:
the desk I have is capable of outputting 4 universes to physical output 1 or 2.
You can route any desk universe (any universe between universe 1-64) to either of the DMX outputs. To do this, tap SETUP -> Universes -> scroll down to the desk universe you wish to route from the console. Then open the panel for that universe, and you can then route the universe over Ethernet, or from either/both of the DMX outputs. To do this click Add under DMX, type the port number (either 1 or 2), and click OK. If that output is currently transmitting a different desk universe, you will get a popup to warn you of this, which you can then click OK. You will then have a RigSync option appear for that output.
Hope this helps,
  • 6 months later...
Bonjour,
Si vous disposez d'un FLX à 4 univers (2048 canaux), vous pouvez ajouter des univers DMX supplémentaires, jusqu'à un maximum de 16 univers (8192 canaux). Ces univers peuvent être patchés sur 64 univers.
https://zero88.com/upgrade/
J'espère que cela t'aides,
If you have a 4 universe (2048 channels) FLX, you can add additional DMX universes, up to a maximum of 16 universes (8192 channels). These universes can be patched across 64 universes.
Hope this helps,
Bonjour,
oui ensuite il est possible de faire cumuler plusieurs console ensemble.
FLX 1 Univers 1 à 16
FLX 2 Univers 17 à 32
FLX 3 Univers 33 à 48
FLX Univers 49 à 64.
Cela fait deja pas mal de choses possibles...
1 FLX + 1 wing  "7.14" + 1  FLX "7.13" & 3 Wings  / 2 Touchscreen  // Jester 24/48
2 Swisson XND-4R5 ENode  // Stairville : 5 Wash MZH 19X15w  - 31 Retro Flat Par 18X 12w RGBW
LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W   // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w
