denis Posted May 25, 2004 Report Share Posted May 25, 2004 when programming a memory, a speed of fixture's movement is set from a console. please, inform how to control (change) this speed when memory is running/activated? [we use ProSpot 575 LX, Coemar]. Quote Link to comment Share on other sites More sharing options...
K-Nine Posted May 25, 2004 Report Share Posted May 25, 2004 I'm not quite sure I follow what you are asking for here as the fixture type does not appear to have a pan/tilt or movement speed parameter. Are you perhaps referring to the fade time for the position parameters (Pan/tilt) when you trigger the memory from the playback X ? If so, you need to set the Position action to fade and the LTP fade time for the time that you want - then when the memory is triggered, the fixture will move from it's current position to the programmed position in the LTP fade time. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
