Howartp Posted February 13, 2020 Report Posted February 13, 2020 Evening! I patched in our back line of halogens a fortnight ago, desk channel 35, DMX channel 26. They were working all night whilst I focussed. The next night, @robhurt came to program and the halogens weren't working - channel 35 was still patched as a dimmer fixture but with no DMX assignment. We patched back in and continued. Rob has saved to his USB stick every night after programming or rehearsals. Tonight we've come to run a rehearsal and the DMX assignment is missing again... Attached is last night's saved file. Thoughts? Peter Red Riding Hood 2020.isf Quote
Edward Z88 Posted February 14, 2020 Report Posted February 14, 2020 Hi Peter, The only thing I could think happened, is that you patched fixture 35 in the Fixture Schedule, focused whilst still in the Fixture Schedule, and then switched the console off. Setup settings and patch will not be saved continuously whilst you're in Setup, hence why you see the save text when you exit Setup as all your changes are saved. Could this be what you did? Could you have edited another fixture's address to conflict with fixture 35? If so you will have received a warning, where if you had pressed "Patch Anyway", the console will have removed fixture 35's DMX address. I noticed fixture 36 is also unpatched, so perhaps the same happened to this fixture? Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Kay Posted February 14, 2020 Report Posted February 14, 2020 "Automatic" and "patching (unpatching)" sounds like RDM to me. Maybe it is turned on and does some silly things? Just an idea. Quote
Howartp Posted February 15, 2020 Author Report Posted February 15, 2020 On 2/14/2020 at 10:03 AM, Edward- Z88 said: Hi Peter, The only thing I could think happened, is that you patched fixture 35 in the Fixture Schedule, focused whilst still in the Fixture Schedule, and then switched the console off. Setup settings and patch will not be saved continuously whilst you're in Setup, hence why you see the save text when you exit Setup as all your changes are saved. Could this be what you did? Could you have edited another fixture's address to conflict with fixture 35? If so you will have received a warning, where if you had pressed "Patch Anyway", the console will have removed fixture 35's DMX address. I noticed fixture 36 is also unpatched, so perhaps the same happened to this fixture? Edward Hi Edward No, I certainly came out of setup after patching - remember this has happened twice now, once when I had been doing patching, then a few days (and rehearsals) later. We haven't added any fixtures since 35 (36 was going to be smoke but we abandoned that) and all other fixtures were already patched and set. We have RDM turned off as our Robe 600's don't like it. Fixture 35 is a dimmer channel on a Chilli 2410 pack (we've two making 48 channels) so no RDM either. Peter Quote
Edward Z88 Posted February 17, 2020 Report Posted February 17, 2020 Hi Peter, On 2/15/2020 at 11:33 PM, Howartp said: We have RDM turned off Even if RDM was enabled, this wouldn't unpatch a fixture. On 2/15/2020 at 11:33 PM, Howartp said: Fixture 35 is a dimmer channel on a Chilli 2410 pack (we've two making 48 channels) so no RDM either. As a side note, the newer Chilli dimmers are RDM enabled. On 2/15/2020 at 11:33 PM, Howartp said: We haven't added any fixtures since 35 (36 was going to be smoke but we abandoned that) and all other fixtures were already patched and set. I don't see any reason why this fixture would unpatch itself. If it happens again, please save and send the show file again with the fixture still unpatched. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
