Set encoder wheel function on fader
Hi Mil,
Yes, there are two ways of doing this.
The simplest way, is holding SETUP, and tapping the playback’s button. This will open the playback settings, when you can enable Effect under fader controls. As well as controlling intensity with the fader, it will also control the effect speed and size.
The other option, is to use Speed Override. Speed override can be found on the second encoder wheels when you press Z/Shift. This allows you slow down or speed up any active effects in the currently viewed playback. To change which playback you are viewing, press and hold VIEW, and tap the playback you wish to view.
Hope this helps,
