Happypally Posted February 6, 2020 Report Share Posted February 6, 2020 I know that I need to create a chase under its own playback stack but how do I get it be triggered from cue 35 on the master playback? Thanks Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted February 6, 2020 Report Share Posted February 6, 2020 Hello, Welcome to the Zero 88 Forum. 30 minutes ago, Happypally said: how do I get it be triggered from cue 35 on the master playback? To trigger a chase on a playback from a cue, click the Settings button of the cue you wish your chase to start in. The Settings button is found at the end of a cue's row. From the Settings, click Macros..., and then choose Trigger Cue Stack. You can then press the flashing button of your chase on the console, or press the chase on the touchscreen. Then OK the Macros window, and OK the Cue Settings window. Now when you go into the cue, the chase will fade in using the cue's fade times. You will then need to go into the settings of the cue you wish the chase to stop in, but this time choose Release Cue Stacks. For more information, see page 50 of the FLX range manual. Hope this helps, if you have any questions let me know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
Happypally Posted February 8, 2020 Author Report Share Posted February 8, 2020 Great thanks for that Quote Link to comment Share on other sites More sharing options...
