Dominique Posted February 3, 2020 Report Posted February 3, 2020 Hi all, I am starting on a FLXs24 (a very good product). However, I don't understand why, if I create a Playback (example Playback 1), I lose access to the Master Playback: it still works, but impossible to create / modify its Cues (disappeared in the "View"). Any help here? ;-) Many thank's in advance. Dominique, from France. Quote
Edward Z88 Posted February 3, 2020 Report Posted February 3, 2020 Hi Dominique, Welcome to the Zero 88 Forum. 17 minutes ago, Dominique said: I am starting on a FLXs24 (a very good product). Really glad to hear you are enjoying your FLX S24. 17 minutes ago, Dominique said: I lose access to the Master Playback: it still works, but impossible to create / modify its Cues (disappeared in the "View"). Any playback on the FLX S24 can be viewed in the cue list window. To view a playback, press and hold VIEW, and tap the playback button you wish to use. Doing this will not change the button function of any playbacks, simply display the cues stored on that playback in the Cue List window. You can see which cue you are in on the MFF Playbacks, by viewing the Faders window. Every Playback will display a "C" and "N", for Current Cue and Next Cue. Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Dominique Posted February 3, 2020 Author Report Posted February 3, 2020 Hi Edward, ok, many thank's ! regards from France. Quote
