Default colour for RGBW fixtures
I'm using a FLXs 48 with a a dozen or so Selecon PL1 RGBW fixtures. We mainly do event and conference work so 90% of the time I want these in a warm white to match the Source 4s we also have. Is there a way to set a default colour for these so when programming I only need to set a colour when they are not white?
thanks,
Chris
Hi Chris,
Welcome to the Zero 88 Forum.
Yes, as @kgallen mentions, this is done by setting all fixtures to the values you wish them to default to, and then tap RECORD, followed by tapping the Home icon. To do this you will need to record the fixtures in their colour, however at 0% intensity. To do this you will need to disable SmartTag within the Record Options. For more information, see below...
http://support.zero88.com/1011707631
Hope this helps,
Product Specialist
Email Support
