terryb Posted January 29, 2020 Report Posted January 29, 2020 Since installing the latest operating version on our FLX S48 it has been a really nice board to drive. However, on two occasions the desk has locked up with none of the buttons responding and the screen going blank. The external touch screen monitor does display the cues but does not respond. The only solution is to switch off for a full thirty seconds and then reboot. Anything less does not produce a clean reboot. Because the screen goes blank it is not possible to examine the event monitor before rebooting. Has anyone else had this little nasty? It has only happened so far while plotting. Quote
Jon Hole Posted January 29, 2020 Report Posted January 29, 2020 Hi Terry, Sorry to hear that. When you turn the console back on, are you offered a debug file? If so, did you save it? Please can you confirm which version of both Software and Co-Processor the console is reporting? To find these, got to (Z) > "System information" and read "Co-Processor Firmware" and "Software Version". Quote Jon Hole linkedin.com/in/jonhole
terryb Posted January 30, 2020 Author Report Posted January 30, 2020 Hi Jon, No there wasn't a debug file offered. I have seen them before so I won't have missed it. I will check the desk later but I updated to the latest software just before I started on this show because I couldn't load the latest fixture file without it (?) I will check the information that you asked for when I get to the desk later today. If I try to reboot too early it just returns to the faulty state. Quote
Jon Hole Posted January 30, 2020 Report Posted January 30, 2020 Thanks Terry, let us know what the desk says it's running, even if that's different to what you think it should be running! Quote Jon Hole linkedin.com/in/jonhole
terryb Posted January 30, 2020 Author Report Posted January 30, 2020 Software 7.9.7 Quote Co processor 2.2.0.0 Quote
terryb Posted January 30, 2020 Author Report Posted January 30, 2020 It just did it again. This time I was in Faders and the console locked with the Z in a circle and a progress bar at about 60%. The first reboot failed and the second did produce an error message which I will forward tonight. Quote
Edward Z88 Posted January 30, 2020 Report Posted January 30, 2020 Hi Terry, 1 hour ago, terryb said: The first reboot failed and the second did produce an error message which I will forward tonight. Please email us a copy of this message to support@zero88.com. We will then be able to investigate this to see what the cause may be. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
terryb Posted January 30, 2020 Author Report Posted January 30, 2020 I have sent this now. I would have done at the time but I didn't have access to USB C adaptor. Quote
Edward Z88 Posted January 31, 2020 Report Posted January 31, 2020 Hi Terry, 14 hours ago, terryb said: I have sent this now. Thanks very much, I have replied to your email. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
terryb Posted February 13, 2020 Author Report Posted February 13, 2020 Just to bring this to a conclusion, the console was not at fault. The problem lay within a powered USB hub that I was using with the desk. Although it had good reviews when I purchased it, subsequently people had a lot of issues with it. Using a passive hub brought no recurrence of the problem. 1 Quote
