stowedout Posted January 25, 2020 Report Posted January 25, 2020 Does anyone have their own Clay Paky Alpha Beam 300 (Vector mode) fixture profile? The one on the Fixtures database has a fair bit of data missing. I'll re write one but just in case some one has done all the work already I thought I would ask. Cheers Chris Quote
Edward Z88 Posted January 25, 2020 Report Posted January 25, 2020 Hi Chris, If you drop us an email to FixtureSupport@zero88.com with details on what is missing, we’ll be able to take a look and add this in. Edward Quote Edward Smith Product Specialist Email Support
stowedout Posted January 26, 2020 Author Report Posted January 26, 2020 Thanks Edward. I'm happy to have a go at this, I could do with keeping my hand in. If I do this do gobo images have to be 25x25 pixels? Ch5 no strobe info Ch7 There is no gobo info Ch13 No reset info appearing on the beam page ch14 No lamp control On further inspection the colour wheel on Ch4 might be more complex than I first thought. The fixtures have 3 possible settings available on their control panel 1 Linear Colour. 2 Full Colour and Rainbow effect . From combinations of having these on or off it gives 6 different variations of the way Ch4 behaves. The Clay Paky manual doesn't make it easy but I have attached it if that helps And the brochure has some better images of the gobos https://www.claypaky.it/media/documents/Alpha300_Brochure_EN.pdf Cheers Chris HR_AlphaBeam300_Manual_05.2015.pdf Quote
kgallen Posted January 26, 2020 Report Posted January 26, 2020 36 minutes ago, stowedout said: If I do this do gobo images have to be 25x25 I’ve often just used a screen grab from the pdf manual, so no it can be whatever it is. When you read it into the Detail tab then it gets scaled. Kevin Quote
stowedout Posted January 26, 2020 Author Report Posted January 26, 2020 Cheers Kevin, Thanks for that. Chris Quote
kgallen Posted January 27, 2020 Report Posted January 27, 2020 That manual looks really good. I think you have all the info there you need. If you need any tips then have a look at a MAC250 or MAC500 fixture profile as it will have similar entries. Give me a shout if you want me to have a bash at making one as an example. Kevin Quote
