Kay Posted January 19, 2020 Report Posted January 19, 2020 Hi Team, while testing I selected some moving heads, and applied different effects (Chaser, Circle, Rainbow) at the same time. Question is, how to unassign one of the effects, if e.g. I do not want the rainbow effect anymore. Second question, if I save this into a playback, is there any way to find out afterwards, which effects where used for this playback? Didn't find any answer in (german) manual. Thanks, Kay Quote
Edward Z88 Posted January 20, 2020 Report Posted January 20, 2020 Hi Kay, 12 hours ago, Kay said: Question is, how to unassign one of the effects, if e.g. I do not want the rainbow effect anymore. After applying multiple effects, to remove one of them, tap the Effects tab, until you see "Exx Size", on the second encoder wheel, where xx is the number of the effect you wish to remove. For example "E21 Size" for the Auto Rainbow effect. The effect numbers are displayed in the auto effect palettes. Then dial the size to 0. The effect is then removed. 12 hours ago, Kay said: Second question, if I save this into a playback, is there any way to find out afterwards, which effects where used for this playback? To find out which effects are running, select your fixtures, tap Effect, and the active effects will be displayed on the wheels. Tap the Effect tab to cycle through the active effects. Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted January 20, 2020 Report Posted January 20, 2020 Edward. This is great. Please create a KB article with this info! Thanks, Kevin Quote
Edward Z88 Posted January 20, 2020 Report Posted January 20, 2020 3 hours ago, kgallen said: Edward. This is great. Please create a KB article with this info! Thanks, Kevin Added to the article below... http://support.zero88.com/1011404471 Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
