Oliver Böckler Posted January 19, 2020 Report Posted January 19, 2020 I use the S24 and have 4 Scanner Stairville SC-X 50 MK2 and Two Showtec Explorer 250 Pro Moving Head. I need a solution to set the FOCUS of every Lamp to an individually default value to make the beams and gobos sharp. Quote
Edward Z88 Posted January 19, 2020 Report Posted January 19, 2020 Hi Oliver, Welcome to the Zero 88 Forum. 1 hour ago, Oliver Böckler said: I need a solution to set the FOCUS of every Lamp to an individually default value to make the beams and gobos sharp. The way this is typically done is using Beam palettes. To do this, turn each light on, and individually set their focus to the value you need to make your Gobos sharp in your chosen position. Then tap RECORD, and tap an empty Beam palette on the touchscreen, marked with an asterisk. Now whenever you select any of your fixtures, you can simply tap this Beam palette, and they will recall your custom focus. Hope this helps. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
