MylesBSN Posted December 24, 2019 Report Posted December 24, 2019 I am currently trying to use phantom and MagicQ vis to preview lighting without access to the kit however I am running into some issues. The problem is that even though the visualiser is running on the same pc and phantom should output Artnet over the loop back the visualiser doesn’t receive this and therefore I am a bit stuck as I need the visualiser to be able to test but can not afford capture etc. How can I get these programs to work without buying the unlock or are there any free alternative visualisers the community can suggest that do work with locked phantom? Quote
Erics Posted December 25, 2019 Report Posted December 25, 2019 You need a unlockdongle to output Artnet from pantom Os to the visualizer. Without the dongle you can't get DMX vaules out of the zerro software. But you can use chamsys software with the magic Viz for one universe for free. Quote I use: Zero 88 FLX S48 / ETC ColorSource 40 / GLP Creation 4096 / Chamsys MQ70 / Madrix
MylesBSN Posted December 25, 2019 Author Report Posted December 25, 2019 How does it work with capture and stuff then? That works without the unlock but I’m stuck unable to afford it so I need an alternative, any ideas? Quote
Jon Hole Posted December 25, 2019 Report Posted December 25, 2019 Phantom ZerOS and Capture talk using CITP. When using a real console (or Phantom with an unlock dongle), this is “normal” CITP. When using Phantom without the unlock dongle, only Capture software can decipher the CITP messages. Quote Jon Hole linkedin.com/in/jonhole
