kgallen Posted December 19, 2019 Report Share Posted December 19, 2019 Here are fixture definitions for: Showtec Shark Wash Showtec Shark Zoom Wash Showtec Shark Combi Spot The ones in the library don't quite match the fixture behaviour (e.g. Combi Spot gobos are incomplete/out of order). showtec_shark.ift Quote Link to comment Share on other sites More sharing options...
kgallen Posted December 19, 2019 Author Report Share Posted December 19, 2019 Edward - there seems to be an issue with the order in which FLX displays the gobo preview images for the Combi Spot - the fixture definition is correct regards the thumbnails and the palettes are correct when the FLX encoder middle button for "gobo" is pressed, but the Auto-palettes generated under Beam have the gobo pictures shifted by one position - the split circle gobo should be "gobo 1/1" but is pictured for "gobo 1/7". I've factory reset the desk and started from scratch and this is repeatable. Why is this? (ETA same behaviour in 7.9.7 as 7.9.5, fixture is Showtec Shark Combi spot as above, and is the only fixture patched). Photos attached. Palettes created by auto-palette. Note the split circle is 1/7, should be 1/1 and the rest shifted along by 1. See the encoder palettes in the second picture, where the gobo thumbnails are in the correct positions and result in the correct gobo in the fixture. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 19, 2019 Report Share Posted December 19, 2019 Hi Kevin, Interesting, thanks for the information. I’ll take a look into this when I’m next in the office. If you have any questions let me know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
