Hi,
I bought a FLX S24 console, I try to visualize on Capture but I don't succeed.
I linked the console directly to the computer with Ethernet cable
Enable Capture is on enabled
Use DHCP dress is on Enabled
Every parameters on Capture are "Automatic"
How can I visualize the show on capture?
Welcome to the Zero 88 Forum.
If you just have a single Ethernet cable linking the console to your iMac, you will have to configure static IPs, not DHCP. DHCP can only be used if there is a DHCP server on the network, such as the one usually part of a wireless router.
Therefore if using a single Ethernet cable, set static IPs and subnets, such as 10.1.1.1 for the CITP protocol on the console, and 10.1.1.2 for the iMac, both with subnets of 255.255.255.0.
You will then need to restart Capture. You should find if you tap Z/Shift -> System Information -> System Text on FLX S, the console reports that it has found Capture on your iMac and is connected. Tap Network Overview for the console’s status.
  • 1 year later...
On 12/19/2019 at 8:54 PM, Edward Z88 said:
Hi there ! I've followed your recipe and Capture is present in Network Overview , but  not in System Text . Flx S24 Software 7.9.9     i-Mac Catalina 10.15.7
Capture (Club) is working fine on the Mac , but no connection ???
regards
Sven
Hi @Sven Nilsen
regards
Sven
Can you confirm whether you are using the same static IP addresses, for both the Ethernet IP of the iMac and the CITP IP on FLX S24, as the addresses in my previous post...
You don't have to use these addresses, but these should get you up and running.
Hi there !
Static IP`s and subnets are the same as you suggested . The Club Capturefile is working fine on iMac (using the mouse) and Club isf installed on the console . Capture is present in Network Overview , but not in System Text . DMX disabled !?!?
Sven
Hi Sven,
Thank you for the update.
I would recommend using our latest versions of the Capture visualisation files, along with the latest versions of the ZerOS show files. These are available to download along with instructions, from the link below...
https://zero88.com/manuals/zeros/networking/connecting-to-capture
I hope this helps, please let me know how you get on.
Hi Sven,
26 minutes ago, Sven Nilsen said:
Hi !
Have already tried these , but Mac will not open 2021 Z88 or the zipped Z88.bin !?!?
Sven
Thank you for letting me know. After unzipping/extracting the files, you should be able to run one of the downloads as an app. Please let me know how you get on.
