Lost_soundguy Posted December 18, 2019 Report Posted December 18, 2019 Hi! Console FLX S24 (2 universes) As I mentioned above, when I'am "programming" in channel mode grabbing different LED cans by the flash buttons. The console automatically "selects" or "de-selects" fixtures that I'am working with at the moment. What could this issue relate to? It's quite the struggle when you are recording to playbacks, and you always have to check before hitting record that the console did'nt de-select a fixture of it's own... Thank you for otherwise great console. But I really need help with this one... Cheers/// Vilhelm Quote
Edward Z88 Posted December 18, 2019 Report Posted December 18, 2019 Hi Vilhelm, What software version is your FLX S24 running? You can find out by tapping Z/Shift -> System Information. In this window is a line of text displaying the Software Version. The latest version is ZerOS 7.9.7. You should find that when you raise a fader, the fixture selects automatically. If you then apply a palette for example, and then push up another channel fader, this new channel selects and the old one is automatically deselected. Hope this helps, if you have any questions let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
