Techie_v2 Posted December 15, 2019 Report Share Posted December 15, 2019 I operate an flx with just a monitor, not a touchscreen and like to use a keyboard on the console controls to move around the cue list and set fade times for colours and intensities etc. Sometimes the "cursor" (the bit I'm selecting with the left, right, up & down arrow keys on the keyboard) gets itself up onto the fixture list so when I move left and right it just moves along the fixtures. Through some kind of dark art I manage to get it back onto the cue list by pressing the view button lots of times and other buttons but dint know exactly how I've done it. What is the way, without a touchscreen, to get the cursor down onto the cue list when it is up on the fixture list? Thanks Quote Link to comment Share on other sites More sharing options...
kgallen Posted December 15, 2019 Report Share Posted December 15, 2019 I’ve had a similar experience when no mouse is attached. I think Edward says the View button does the trick. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 15, 2019 Report Share Posted December 15, 2019 Hi both, When you boot the console, by default the selected window is the Output Window, meaning the cursor keys control this. To select the cue list window, press VIEW and then SHIFT + VIEW to go back into the Cues desktop. The cursor keys will navigate the cue list window. With a Mouse/Touchscreen connected simply tap on the window you want to use. Hope this helps, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
Techie_v2 Posted December 15, 2019 Author Report Share Posted December 15, 2019 Thanks'll I'll check this out tomorrow! Quote Link to comment Share on other sites More sharing options...
Techie_v2 Posted December 17, 2019 Author Report Share Posted December 17, 2019 Couldn't seem to get this to work, when I used Shift + View to go back the cursor was still in the channel window, not the cue list. If I remember, going into setup and back out again moved the cursor into the cue list but I'll confirm that later. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 17, 2019 Report Share Posted December 17, 2019 Hello, 5 hours ago, Techie_v2 said: If I remember, going into setup and back out again moved the cursor into the cue list but I'll confirm that later. OK no problem, let us know how you get on. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
