Nick Charalampidis Posted December 13, 2019 Report Posted December 13, 2019 Hi! I have a problem with flx s48 firmware update. I make all steps like that say in this http://support.zero88.com/Legacy-Products/Legacy-Consoles/Legacy-ZerOS/1518909581/ZerOS-Software-Update-on-Consoles-running-ZerOS-7-8-2-39-or-older.htm An i tried to make the step for the bootable usb. I see this steps o this http://support.zero88.com/Legacy-Products/Legacy-Consoles/Legacy-ZerOS/ORB-XF/998317101/Advice-when-performing-ZerOS-software-upgrades.htm But the problem remains. I 'll tried to install first the version 7.9.5 and after the version 7.9.6. But nothing. My console is Zero88 FLX S48 with firmware version 7.9.4.3. My USB Stick is Kingstone 32GB Data Traveler SE9 DTSE9G2. Windows PC Thank you in advance! Quote
Edward Z88 Posted December 13, 2019 Report Posted December 13, 2019 Hi Nick, The article on our website you linked to is for consoles running ZerOS 7.8.2.39 software or earlier. To update the console, follow the steps in the release notes, or the ones in the article below... http://support.zero88.com/1518910761 Hope this helps, Edward Quote Edward Smith Product Specialist Email Support
Nick Charalampidis Posted December 13, 2019 Author Report Posted December 13, 2019 Thank you for your reply. When i go on setup-->Load i see my usb stick but look like an emty usb stick. When i put the usb stick on pc i see the instalation folder and a boot file. Quote
kgallen Posted December 13, 2019 Report Posted December 13, 2019 The file should be in the top directory of the usb stick - not in a folder. Quote
Edward Z88 Posted December 13, 2019 Report Posted December 13, 2019 Hi Nick, The console simply requires the ZerOS OS USB Creator application file, with the .exe file extension. Click the .exe file, and the console will then begin the upgrade. As Kevin says, make sure the install file is on the roof of the USB stick, not inside any folders. Hope this helps, Edward Quote Edward Smith Product Specialist Email Support
Nick Charalampidis Posted December 14, 2019 Author Report Posted December 14, 2019 Guys thunk you very much i done the update!! Thunk you!! Quote
Edward Z88 Posted December 14, 2019 Report Posted December 14, 2019 Hi Nick, 33 minutes ago, Nick Charalampidis said: Guys thunk you very much i done the update!! Thunk you!! No problem, glad to hear it. Any questions just let us know. Edward Quote Edward Smith Product Specialist Email Support
