coellen_d Posted December 7, 2019 Report Posted December 7, 2019 Hi there, hope, anyone can help me with this problem: I use a Leap Frog 96 with actual zerOS 7.9.6 I set up a simple tilt move effect with 4 moving heads, connected to DMX universe1, using DMX out on the desk. The effect runs very smooth and stable until I do the following: - change the page of the submasters - change the page of the MFKs - change the MFKs section - do any other change that results in a rewrite of LCDs the DMX output stucks for a short while, until page setup has finished and LCD write has finished. I also tested this behaviour with an effect-based shutter chase and a chaser-based Tilt move. I do not have any problems while changigng pages, if there is no change on LCD. For example change submaster bank without any submaster named or used. So I came to the conclusion, that writing to the LCDs does disturb continous calculations and/or DMX output for a short while. After searching in the forum a lot I think, there is no difference between Leap Frog and solution hardware. So what is my problem? Actual I can't use the desk for a show, because almost every user action does disturb the output. I have this problems also with earlier versions of zerOS. Many Thanks for Your help! Dirk Quote
Edward Z88 Posted December 7, 2019 Report Posted December 7, 2019 Hi Dirk, Sorry to hear this. Thank you for your detailed description. Please could you email support@zero88.com with a copy of your show file that shows this issue. If you have any questions let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
coellen_d Posted December 10, 2019 Author Report Posted December 10, 2019 Hi Edward-Z88, excuse the delayed answer, I posted the showfile an a short video on support@zero88.com. Many Thanks for Your help again! Dirk Quote
Edward Z88 Posted December 11, 2019 Report Posted December 11, 2019 Hi Dirk, We have received this and are looking into it. If you have any questions let us know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
