nbaldwin Posted December 7, 2019 Report Posted December 7, 2019 (Leapfrog 96, ZerOS 7.9.5) Is it possible to copy Cues from one Show file to another via the console? Or failing that, is it possible to do it with a text editor or such? This feature would really, really help me out over the next two weeks! Cheers, Neil Quote
Edward Z88 Posted December 7, 2019 Report Posted December 7, 2019 Hi Neil, Currently only whole shows can be saved. Individual playback’s/ cues can’t be exported/imported. There is no way of editing a .isf file. Are you using a show file with the same patch, and want to use a cue from a previous show with the patch? If so you’ll have to rebuild it. You may find Phantom comes in really useful here. You could have Phantom on a PC running with the original show file, and you can then recreate the levels on the LeapFrog, and when you’re done record the cue. Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
nbaldwin Posted December 7, 2019 Author Report Posted December 7, 2019 That's a real shame. Basically I programmed a load of cues in a show and then realised I'd loaded the wrong show Coincidentally I spotted this in the release notes for 7.9.6 - "ASCII showfile importing". What does that do? Quote
Edward Z88 Posted December 8, 2019 Report Posted December 8, 2019 Hi Neil, 14 hours ago, nbaldwin said: Basically I programmed a load of cues in a show and then realised I'd loaded the wrong show Oh dear sorry to hear this. 14 hours ago, nbaldwin said: Coincidentally I spotted this in the release notes for 7.9.6 - "ASCII showfile importing". What does that do? ASCII Show files are show file formats that some lighting consoles from different manufacturers can export, which ZerOS can then load in. For example you could export a show from an ETC Ion and load it in to ZerOS. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
