Hi Richard,
Welcome to the Zero 88 Forum.
If the dimmer is reporting that the Alarm is Active, it means the alarm 0v and alarm AL terminals are connected. These terminals are on the same 4-way screw terminal block as the DMX connections, found on the control PCB.
These terminals are RS485-, RS485+, 0V and AL. Has the DMX been wired into the correct terminals?
If you have any questions let us know.
