2 threads in 1 day... sorry...
I have since upgraded to the latest FW and all is working well, with the exception on 1 "glitch" that i hadn't noticed in previous versions...
I have a few simple chases programmed to individual MFFs. These are set to global bpm and a number of them have either cross fade or ramp up / down applied to them. I have then set the "play" button of the master play back to be a tap tempo for global bpm. With the latest firmware i have noticed that when global bmp is applied to the chase mff, the ramp up / down or cross fade options are ignored and the chase steps "snap". Is this a known glitch? or something that has always been present but I've overlooked? and is there a way to combat this?
Olly
Hi Olly,
I have just tried to recreate this on Phantom ZerOS, and I can't recreate.
What are the fade percentages configured to for these chases?
If you send a copy of your show file to support@zero88.com, we will be able to take a look, and see what may be causing this.
Product Specialist
Email Support
Thanks for the reply.
The fade intensity of the fixtures is100% when the chase was programmed. The ramp up setting is also 100% in the mdf settings page. I have an inhibit set for the fixtures in the chase set to 70% for fixture 1 and 100% for fixture 2.
i will send the show file once I get back to the venue.
