Can I use 'Solo' effect on Cue Stack
Hi Mac,
Yes, if you want to solo the current cue in a cue stack, you can configure the button function. The default button press for a cue stack is Go Fade, which you’ll probably still want, and the default shifted button press is Go Snap. You could therefore configure the shifted button press to be solo. To do this hold SETUP and tap the playback’s button, and then hold SHIFT and choose Solo. Then click OK on the playback settings window.
Hope this helps,
