when i install an update do i install the most recent, 9.6? or do i have to go a little further back version 9? i just thought i saw it some where on here? :?
thank you
You should update to the latest version 9.6
version history:
Version 9.0
  • Beat Drive modifier for Chases.
  • Live Adjustment of Chase Modifiers (Direction, Attack, Drive, Speed).
  • Pan/Tilt Reverse and Pan/Tilt Swap Functions for fixtures.
  • Desk Defaults - reorganised into Memory, Submaster and SX sections.
  • Submaster pages increased to 20.
  • Fade Times and LTP actions editable on submasters programmed with channel data or transferred memory.
  • Submaster name displayed on main LCD.
  • Fade Times and LTP actions can be adjusted on SX buttons programmed with channel data or transferred memory (Mambo Frog).
  • N-Shot Chases - new parameter which determines how many times the chase runs when triggered.
  • Palette Lock Function.
  • Edit Blind Function (Memories, Submasters, SX Buttons).
Version 9.2 (Bugfix)
  • contains some bug fixes relating to the Edit Blind function
Version 9.6 (Bugfix)
  • Frog Reference No 5482 - Movement effects appear on memories after reloading show file from floppy or power cycling the desk.
Sebastian H.
Pro - Sound Showtechnik
Albert Einstein
Al Capone
