stowedout Posted November 13, 2019 Report Posted November 13, 2019 Hi Folks, I have programmed a MFF's to introduce a figure of 8 effect on a group of fixtures. The fader is set to control the "effect" so the further the fader is raised the speed and amount of effect is increased. Once the MMF is in the required position the result is as I expected. However when the fader is moved from 0 to 25% for example(which will result in a small slow figure of 8 the fixtures make an initial fast movement copying the speed I have moved the fader. The visual result is that the flown fixtures are pointing towards the stage they shoot 30 degrees to stage left then a figure of 8 takes over. I compensate for that by raising the MFF very slowly so it appears to the audience to be part of the figure of 8. Although when busking a show its easy to forget and get it looking a bit rubbish. Thoughts? Chris
kgallen Posted November 13, 2019 Report Posted November 13, 2019 Guessing now... is there a "fade" time you can apply to the Raise Fader that will do the "gentle introduction" for you?
Edward Z88 Posted November 13, 2019 Report Posted November 13, 2019 Hi Chris, Does your effect playback also include position information? If so when you raise the fader, position will still use the cue's fade times whereas effect will be scaled by the fader position. To avoid the jarring position, you therefore may want to increase the position fade. To do this hold VIEW and press the playback button. You can then edit the position fade time. You may find that enabling fader controls position as well as fader controls effect on the same playback also solves the issue. Hope this helps, if you have any questions let me know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
stowedout Posted November 13, 2019 Author Report Posted November 13, 2019 Thanks Edward and KGAllen I will check that out tomorrow and report back Chris
stowedout Posted November 20, 2019 Author Report Posted November 20, 2019 Hi Edward you were spot on. There was position data recorded as well. I deleted the cue and rerecorded with effect data only. Had I wanted to edit the position data ,in your previous reply you said "hold VIEW and press the playback button. You can then edit the position fade time." is that a shift option in the position window? Chris
Edward Z88 Posted November 20, 2019 Report Posted November 20, 2019 Hi Chris, If you hold VIEW and press a playback button, this will open the playback in the cue list window. You can then edit fade times by tapping on the fade time value, and use the encoder wheels to set the time. Hope this helps, Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
