ethan1997may Posted October 30, 2019 Report Share Posted October 30, 2019 Hi I was using the desk the other day and recorded some effects on playbacks. The issue I was having was everytime i released the playback the movers all returned to their home position. Is there a way to stop them doing that? Thanks Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 30, 2019 Report Share Posted October 30, 2019 Hi Ethan, Yes, to stop fixture’s going back to their defaults when the playback fader is lowered, you can disable “Release on Lower”. To do this hold SETUP and tap the playback’s button. Then tap Raise & Lower, and then choose disable Release on Lower. Then click OK. You will find when you next lower the fader, the effect continues to run. To manually stop it running, hold CLEAR and tap the playback’s button. Hope this helps, if you have any questions let me know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
ethan1997may Posted October 30, 2019 Author Report Share Posted October 30, 2019 Hi yes the does help slightly but is it possible to do it in a way that when I release the fader it stops the effect but leaves the movers in the position I had selected previously rather than them homing? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 31, 2019 Report Share Posted October 31, 2019 Hi Ethan, 9 hours ago, ethan1997may said: Is it possible to do it in a way that when I release the fader it stops the effect but leaves the movers in the position I had selected previously rather than them homing? There are a couple of options available. The first option is to enable Fader Controls Effect. Doing this means the fader level will control the intensity, and also the speed and size of any programmed effects. To do this hold SETUP and tap the playback's button. Then tap "Effect" under "Fader Controls...", so that it is enabled, indicated with a red stripe. Click OK, and now you'll find as you lower the playback fader the effect stops, however the fixtures stay in position. Another way to do this, you could program a second cue onto the playback, which simply stops the effect running. That way you can lower the playback fader (with release on lower still disabled), press the playback button, and the movers would stop moving. You can then tap the playback button again to start the effect, and fade the intensity over the top. The easiest way to do this is push the playback up, select your fixtures with the effect running, and then hold EFFECT and tap HOME to stop all effects. Then tap RECORD -> tap your playback's button -> Choose Create Cue 2. Hope this helps, if you have any questions let me know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
