Carpo Posted October 29, 2019 Report Share Posted October 29, 2019 Is there an easy way to make a two step playback for haze/smoke? Thinking about: Step 1 (for smoke): 5 to100% "effect" (smoke pump) at 5 to 60 sec (the "effect" is easy to change in the step - but what about time......? Step 2:  0% "Effect" for 30 seconds to ?? minutes. Can´t really figure out how to do it on my FLX S24s 😞 If I make the playback as a chase each step is the same duration........ and it is not working for me....... Quote Carsten Poulsen Carpo Roadshow www.carpo.dk Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 29, 2019 Report Share Posted October 29, 2019 Hi Carsten, Rather than running the cues as a chase, you could configure auto follow-on in the cue settings so that they follow after each other with custom timings. To do this, view the playback that contains these 2 cues by pressing and holding VIEW and tapping the playback's button. Then go into the settings of cue 1, and from the Trigger drop down choose auto after. You can then configure a wait time. This is the time cue 2 is active before cue 1. You can then click OK. Then go into the settings of cue 2, and again set an auto after of the time you wish cue 1 to output before cue 2. Hope this helps, if you have any questions let me know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
Carpo Posted October 30, 2019 Author Report Share Posted October 30, 2019 Brilliant - thank you for the help. As always great support 🙂 Quote Carsten Poulsen Carpo Roadshow www.carpo.dk Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 30, 2019 Report Share Posted October 30, 2019 33 minutes ago, Carpo said: Brilliant - thank you for the help. As always great support 🙂 Hi Carsten, No worries - any questions just let us know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
