JWylie91 Posted October 14, 2019 Report Posted October 14, 2019 Hi all, Just happened to notice something I thought I would question when demonstrating how to renumber a cue stack to my colleague. We had a simple cue stack created and I had demonstrated how to set instructions for cues to jump to specific 'next cues' should he ever have a need to jump around the stack. He then asked me about recording cues in between stack numbers so I showed him which led us onto the renumber function. Upon renumbering the cue stack I noticed that the 'next cue' instructions hadn't updated and would require manually changing. I would have thought that the system would have updated normally to keep the next cue links correct however they failed to update. It seems a bit awkward if you have to go through all of your cue stack checking these numbers each time you renumber. If this is how they have been designed to work then I guess I will have to remember that for future programming however I thought it may be worth looking at for future additions. Cheers Joe Quote
Edward Z88 Posted October 14, 2019 Report Posted October 14, 2019 Hi Joe, Automatically updating Next cues after renumbering cues in a playback is something we are looking to implement in a future software version. This is logged on our software enhancement system as reference number ZOS-8373. If you have any questions let us know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
JWylie91 Posted October 15, 2019 Author Report Posted October 15, 2019 Brilliant, Thanks Edward, Just hit me as something that required flagging up. Joe Quote
