Oli Posted October 10, 2019 Report Posted October 10, 2019 (edited) With FLX S24 we have patched 12 LED Par cans (Starville LEDPar) with 5 channels each starting at dmx address 101. Having addressed the fixtures only the first 6 ones work. Fixture 7 to 12 without reaction. Am we doing someting wrong or is there any restriction? Thanks for answers Edited October 10, 2019 by Jon Hole Please use meaningful topic titles Quote
martin-144 Posted October 10, 2019 Report Posted October 10, 2019 The cable between 6 and 7 is faulty... No, seriously. All the same DMX address or different? Quote
Oli Posted October 10, 2019 Author Report Posted October 10, 2019 35 minutes ago, martin-144 said: The cable between 6 and 7 is faulty... No, seriously. All the same DMX address or different? Already tried different cables 🙂 Yes, DMX addresses in setup are continiously from 101 up to 156 with intervals of 5.  Quote
Edward Z88 Posted October 11, 2019 Report Posted October 11, 2019 Hi Oli, Have the fixtures been daisy chained in order of DMX addresses? If so swap one of the working fixtures with one that isn't, leaving their DMX addresses the same. If you loose control of the working one, and gain control over the other, there is an issue with the DMX line. If you have a DMX terminator to hand it would be worth connecting to the DMX out of the last fixture. 12 hours ago, Oli said: Am we doing someting wrong or is there any restriction? On FLX S24, your control capabilities are a maximum of 48 fixtures, with either 1or 2 universes of patchable DMX channels available, depending on whether you have a 1 or 2 universe variant. Hope this helps, Edward Quote Edward Smith Product Specialist Email Support
