RWillcox Posted October 9, 2019 Report Share Posted October 9, 2019 Hi there, I’m revamping a current show and the running order has changed. Is there any way to copy multiple cues on the FLX s48 to move an entire number or do I have to copy and move each individually? Thanks Rachael Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 10, 2019 Report Share Posted October 10, 2019 Hi Rachael, Welcome to the Zero 88 Forum. This can be done on FLX S48, however only by using an external keyboard. If for example you wanted to copy cues 1 through to 10, and paste them in cues 51 through to 60, you can tap Copy (found by pressing Z/Shift), and type 1>10 in the "From" field, and type 51 in the "To" field. The cues will be copied. To then remove cues 1 through to 10, you can type DELETE 1 THRU 10, followed by pressing the playback button that these cues are stored onto. The console will then ask you to confirm deleting these cues. Hope this helps, if you have any questions let us know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
Lawrence Newbery Posted October 28, 2021 Report Share Posted October 28, 2021 Hi Edward Can this also be done using the Leapfrog 96 using the same syntax commands? Having a similar issue and I have a fair few cues. Thank you Lawrence Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 29, 2021 Report Share Posted October 29, 2021 Hi @Lawrence Newbery Welcome to the Zero 88 Forum. 9 hours ago, Lawrence Newbery said: Can this also be done using the Leapfrog 96 using the same syntax commands? Having a similar issue and I have a fair few cues. Yes it can. To make your life easier, you may wish to use a USB keyboard for this. You will then be able to use this same syntax... On 10/10/2019 at 10:09 AM, Edward Z88 said: If for example you wanted to copy cues 1 through to 10, and paste them in cues 51 through to 60, you can tap Copy, and type 1>10 in the "From" field, and type 51 in the "To" field. For more information on copying, see the link below... https://zero88.com/manuals/zeros/cues-playbacks/copying Hope this helps, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
Lawrence Newbery Posted November 1, 2021 Report Share Posted November 1, 2021 Thank you Edward for the help, this worked exactly how I thought and made life so much easier, I'd completely forgotten how to do it. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 1, 2021 Report Share Posted November 1, 2021 Hi Lawrence, 17 minutes ago, Lawrence Newbery said: Thank you Edward for the help, this worked exactly how I thought and made life so much easier, I'd completely forgotten how to do it. No problem at all, glad to hear it. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
