Can someone help me to create a fixture for this type of lights .. PLEASE!!!
https://www.amazon.com/Ridgeyard-Touch-Screen-Moving-DMX512/dp/B071KNQTL6/ref=sr_1_47?keywords=led+head+moving+light&qid=1565618648&s=gateway&sr=8-47
This are the specifications
Specifications:
Rated power: 300w
Voltage: AC110v, 60HZ
Color: 14 colors + white
Strobe: 0-12 times / second
Reverse: horizontal / vertical
Dmx 512 channel: 16ch / 20ch
Dimmer: 0-100% linear adjustment
Lamp: 230w beam lights with bulb
Fantasy: eight prism effect control
Focus: independent electronic linear focus
Cooling system: built-in convection heat / air
Description trimming (x / y-axis precision): 8 / 16bit
Level of 540°, vertical 270°, horizontal / vertical speed adjustable
Effect:pattern water effects / pattern jitter effect / linear rainbow effect
Control mode: dmx512 / master-slave / auto / sync / voice / lcd display
Fixed gobo wheel: 17 gobo patterns, made from high temperature special materials
Package size: 42x 47x 58cm (16.5" x 18.5"x 22.8") /pc
Weight: 22kg ( 48.5 lb ) / pc
Hi RaffaABC,
The Zero88 guys won't be able to help you with this description. They will need to have a description of how the DMX channels are located.
And if you can find out the channel allocation, you should mail it to FixtureSupport@zero88.com. And maybe here, just for interest.
Martin
  On 10/8/2019 at 8:47 PM, Edward- Z88 said:
Hi RaffaABC,
As Martin says, please send us a link/copy of the fixture’s manual containing the DMX channel map to FixtureSupport@zero88.com, and one of the team will be able to help you out and create the file for you.
All the best,
Expand
Thank you Edward
Here is the Tech Specifications that are on the Manual.
Product name: 7R beam 230W beam moving head
Power supply: AC90-240V, 50/60HZ
LIGHT SOURCE: Ipcs 230W Light bulb
FUSE: 7A
DMX CHANNELS: 16CH
COLOR: 14COLORS-WHITE
PATTERN PLATE: 14PATTERN +WHITE MODELS
STROBE: 0-10TOMES/SEC,ADJUSTABLE SPEED
X-AXIS: 540''
Y-AXIS: 270''
LCD: ON/OFF
PRISM: 8-FACET PRISM (16-FACET PRISM FOR CHOICE)
FOCUS: ELECTRONIC LINEAR FOCUS
FOST: WITH FOST EFFECT
OPERATING MODE: DMX512, SOUND ACTIVED, AUTO, MASTER/SLAVE
BEAM ANGLE: 3, 8''
N. W: 17.5
G, W: 18, 96
Hi Raffa,
We will not be able to make a fixture file from this information.
We need the DMX traits and channel map, that state what each of the 16 DMX control channels does.
If you do find this please email fixturesupport@zero88.com, and we'll be able to make the file for you.
I believe Keith replied to your original email with an existing fixture file that he guessed may give you control over the fixture - I'm assuming this didn't work?
If you can't find the information, you can patch 16 dimmer channels, and work through each one making a note of how it controls the fixture. This method is always difficult with fixtures with shutter parameters as well as dimmers and colour mixing, as many channels have to be at certain levels to get light output.
Yes, that's rigtht Keith replied to me. But  it didn't work
And the manual that it came with the product doesn show any more information about the lights. Don't know what 2 do now..!!
But thanks alot
