Wai Posted September 26, 2019 Report Share Posted September 26, 2019 Hi I am a FLX S24 user form Hong Kong. This is my first time to use the zero88 lighting console. I had a playback problem. (moving head) 1. When i play the Lx cue 1, push up fader then the fixture will go to some position. 2. Then out the Lx cue 1, the fixture will back to home position. 3. When i go to Lx cue 2, the fixture form home position and do the cue. I want to know how to set up. All the Lighting cue playback when fader out the fixture don't go to the home position. Like Avolite console. Other problem, is the dimmer must use the fader to push on ? BR Wai Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 26, 2019 Report Share Posted September 26, 2019 Hi Wai, To stop moving fixtures going back home after lowering a playback fader, hold SETUP and tap the playback's button. From the Playback Settings tap Raise & Lower, and disable release on lower. The playback fader will by default control the intensity level of the playback. Hope this helps, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
Wai Posted October 28, 2019 Author Report Share Posted October 28, 2019 Hi Thank you for your help. the lighting fixture will not back to home. it's ok. but it will over lap and hold the next cue. Play back example: Cue 1 : Moving fixture - Circle LED Par - Bule Cue 2 : Moving Fixture - Next position LED Par - Red Playback : Cue 1 > Cue 2 (the Led Par hold the Blue Color (cannot change) the moving fixture is OK - i choose disable release on lower on play back setting. Is it my step is wrong or i need choose some setting when i record the light cue. BR Wai Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 28, 2019 Report Share Posted October 28, 2019 Hi Wai, When you go from cue 1 to cue 2, you should see your LED fixture fade from red into blue, through magenta. If the fixture isn't changing colour in cue 2, it hasn't been recorded correctly. To update cue 2, firstly go into it, so that cue 2 is displayed green in the cue list window. Then select your fixture that you wish to be red, and make it red. Then tap UPDATE, followed by pressing the playback button these cues are stored on. The cue will be updated. Hope this helps, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
Wai Posted October 28, 2019 Author Report Share Posted October 28, 2019 Hi I want to make sure something : May i go to Set up > Default > Playback Default > Raise and Lower > Trigger on Rise > Enable Release on Lower > Disable I want to do the result Cue go : light cue follow to fader Don't over lap other cue. Cue 2 out Fixture don't back to home position May i know my setting is right ? Coz we always over lap the cue. BR Wai Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 28, 2019 Report Share Posted October 28, 2019 Hi Wai, Could you elaborate on what you mean by 50 minutes ago, Wai said: over lap the cue. When you go from cue 1 to cue 2, unless the fade times are set to 0 seconds, you will see an overlap as you fade from one cue to the other. If you have any questions let me know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
