pierotec Posted September 24, 2019 Report Posted September 24, 2019 SHIFT [Parameter] RECORD Playback.I tried to use this procedure to store a parameter on a playback on new console flx s, but it doesn't work anymore? 😞 P. Quote
Edward Z88 Posted September 25, 2019 Report Posted September 25, 2019 Hello, This syntax was only designed for FROG2 consoles. SHIFT + tapping a parameter name, allows for percentage control of a parameter via syntax. For example SHIFT [Red] @ 50 ENTER, takes the Red parameter to 50%. Individual parameters can still be stored onto a playback. To do this, set the parameter to the level you would like, and ensure no other parameters are stored. You can then store this to a playback, ensuring SmartTag is disabled in the Record Options window. Then hold SETUP and tap your playback's button, and choose Fader Controls for the attribute your stored parameter belongs to. Click OK, and the playback fader will then scale the level of that parameter from its existing value, to the recorded value. Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist -Â Email Support Currently: Obsidian Control Systems Product Specialist
