Carpo Posted September 24, 2019 Report Posted September 24, 2019 Just an advise how to make 4 spots fade from one color to another from, let say left to right, on my FLX S24. Like this; all four spots are red, and the fist spot change to blue and the other tree spots are still red and so one. What effect do I need to use to make it as quick programming as possible. Tried a step with all four spots red and a step with all four spots blue - but I don't get the result I want. I know it should be VERY simple - but I am doing something wrong....... Quote Carsten Poulsen Carpo Roadshow www.carpo.dk
Jon Hole Posted September 24, 2019 Report Posted September 24, 2019 Hi Carpo, You need a four step chase - one step for each fixture turning blue. Should only take a few seconds to program: LED 1 LED 2 LED 3 LED 4 Cue 1 Blue Red Red Red Cue 2 Red Blue Red Red Cue 3 Red Red Blue Red Cue 4 Red Red Red Blue Quote Jon Hole linkedin.com/in/jonhole
Carpo Posted September 24, 2019 Author Report Posted September 24, 2019 Ok, it is the way I have done it so far - it is no problem with two colors but my plan was using more colors and maybe with some chase "back and forth". I was hoping for at more simple and automatic way to do it...... Thank you for the help.... :-) Quote Carsten Poulsen Carpo Roadshow www.carpo.dk
