Sven76 Posted September 19, 2019 Report Posted September 19, 2019 Hi all I'm having a huge issue with the FX palette on our ORB XF running ZerOS 7.9.5: After updating the console to 7.9.5 many FX of our show are not working anymore. Many of them are even "grey" instead of "blue" now, so that I can't even select them (for instance a circle for a moving head or color FX for our RGB(W) fixtures). I then thought: "OK, lets get rid of the old stuff and build it up new from scratch". But with that it got even worth: I deleted all FX on the palette and pressed the "automatic create..." button. But then only very view FX were created, they got spread all over the palette and even them do not work! Does anybody have a similar experience? What could i do wrong? Is there a solution or a workaround? BTW: Even on the Phantom the automatic creation is not working Thanks in advance Best regards Sven Quote
Edward Z88 Posted September 19, 2019 Report Posted September 19, 2019 Hi Sven, After installing ZerOS 7.9.5, if you press "Automatically Create Effects palettes", how many are generated? 45 auto palettes should be generated. You can then select your fixtures, and ones available for those fixtures will be highlighted. If only one "No Effect" palette is created, you will need to reinstall ZerOS. This can be done following the instructions below... http://support.zero88.com/1518910761 Hope this helps, if you have any questions let us know. Edward Quote Edward Smith Product Specialist Email Support
Sven76 Posted September 19, 2019 Author Report Posted September 19, 2019 Hi Edward, thank you for your hint. I will test this over the weekend and will give feedback if it worked. Best regards Sven Quote
Edward Z88 Posted September 19, 2019 Report Posted September 19, 2019 Hi Sven, OK, let me know how you get on. All the best, Edward Quote Edward Smith Product Specialist Email Support
Sven76 Posted September 19, 2019 Author Report Posted September 19, 2019 Hi Edward I was already able to test your suggestion. Unfortunately it didn't work at all. Still, when I press "Automatically create Effect palettes" only the [No Effect] button gets created. I tried the installation 2 times and even did a fresh download and a deep formatting of the stick. No change at all. I then tried to create a FX palette by using Phantom. Phantom was able to create a palette. But after transferring the showfile to the desk non of those FX buttons were usable (all grey). Any further Ideas? I also wrote an email to support including my showfile because I'm really desperate at the moment 😞 Thank you and best regards Sven Quote
Edward Z88 Posted September 19, 2019 Report Posted September 19, 2019 Hi Sven, It sounds like you installed ZerOS 7.9.5 using the old installation method, not the method described here... http://support.zero88.com/1518910761 Please try loading the software application directly into the console like a show file, as described in the link above, and the effects should be installed with the software. Hope this helps, let me know how you get on. Edward Quote Edward Smith Product Specialist Email Support
Sven76 Posted September 19, 2019 Author Report Posted September 19, 2019 Well you are right: I really did it like I was used to 😕 You really believe this might be the root cause? Quote
Edward Z88 Posted September 19, 2019 Report Posted September 19, 2019 Hi Sven, This will be the cause. Effects are not installed when installing software via a bootable USB drive. Edward Quote Edward Smith Product Specialist Email Support
Sven76 Posted September 19, 2019 Author Report Posted September 19, 2019 Ok. Good to know. From time to time reading manuals seems to be a good idea 🤔 I will try over the weekend and give feedback again Thanks and best regards Sven Quote
Sven76 Posted September 21, 2019 Author Report Posted September 21, 2019 I‘m happy to tell you that your hint perfectly worked for me! 😁 After I did the update as it is documented sven.kempf@t-online.de be done all F/X are perfectly working for me. Thanks a lot for the perfect help! Best regards Sven Quote
Edward Z88 Posted September 21, 2019 Report Posted September 21, 2019 Hi Sven, No problem, really glad to hear you’ve solved the issue. All the best, Edward Quote Edward Smith Product Specialist Email Support
