Jake Field Posted September 18, 2019 Report Share Posted September 18, 2019 Is it possible to downgrade from the latest zeros to zeros 7.8.0 as it is the best software to use to teach new tech students in our leapfrog and we tried to downgrade it the same way as you would update but the desk ignored the software and booted as normal Any ideas? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 18, 2019 Report Share Posted September 18, 2019 Hi Jake, Yes, you can downgrade software if you wish. Show files are not however guaranteed to be backwards compatible, only forwards compatible. Before you downgrade, if you haven't seen the video below, it might be worth watching, as it goes through the operation of the console running ZerOS 7.9.2 or later... https://www.youtube.com/watch?v=CjnbGuTHbFA Installation instructions can be found here... http://support.zero88.com/1518909581 ZerOS 7.8.2.39 can be downloaded from the website here... https://zero88.com/forum/files/file/2-zeros-frog2/ Hope this helps, if you have any questions let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
