Tapani Posted September 13, 2019 Report Share Posted September 13, 2019 I have problem with the fade-down on my ETC ColorSource PAR an Spot. The dimming-down on the channels works fine, it dimms slowly. If i dimmimg-down with a programmed-submaster, the last few percents (6-10%) will stop the lights immediately. Does any of you have any idea where the mistake could be? Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted September 13, 2019 Report Share Posted September 13, 2019 Hi Tapani, Hold SETUP and press the flash button below the Playback fader. Click "Raise and Lower" along the top. You can either reduce the "Trigger/Release Level" to 0%, or you can disable "Release on Lower". I suggest changing the "Trigger/Release Level". Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Tapani Posted September 19, 2019 Author Report Share Posted September 19, 2019 Hello Jon Thanks for your help. I remarked, that the problem is only, when the color LIME is programmed. If is disable "Release on Lower", the problem is solved. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 19, 2019 Report Share Posted September 19, 2019 Hello, 3 minutes ago, Tapani said: If is disable "Release on Lower", the problem is solved. Glad to hear this solved the problem. All the best, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
kgallen Posted September 19, 2019 Report Share Posted September 19, 2019 Tapani - are you really solved with this issue because of the Release on Lower setting or do you still have a query related to the lime emitter ‘misbehaving’? With so many emitters in these ETC fixtures you’ll find the other colours on subsequent pages by pressing the Colour button multiple times. If not it would suggest the fixture definition is deficient Sorry if you’re an experienced user and already know this. Quote Link to comment Share on other sites More sharing options...
